Multimedia system Acodo
  • I ask forgiveness, so is the interpreter. I will try again to tell you about the system I have it for 3 years, there have been systemic failures but all were repaired using automatic recovery system. When compared with Blaupunkt NX then there is nothing to compare, as different systems I have Android. Well, now that it works with the standard devices if you are Parking sensors that they work as work, transmission data Convers+ then you are all completely shows if if you have a regular Sony or Blaupunkt NX then the screen shows the name of the radio station + frequency then may the device only shows the purity of the radio station, the pointer navigation is not working!.. But I don't really need, now, about the music; here, too, minus that you have not listened to will always show track 1... and then Leah. If you are interested in something more, ask I will answer you.
