Und jetzt ich noch:
FLH________Eibach (-30mm)_____8,5J20 ET40_____0mm_________245/30 20___keine_______Pit Bull
FLH________OHNE___________8,5J19 ET40_____16mm________225/40 19___keine_______Black_Mustang2
Turnier_____Ford(-15mm)________8,5J19 ET40______0mm________255/30 19___keine_______Peter
Turnier_____H&R (-40mm)_______8,5J19 ET45_____10mmHA/Rad__235/35 19___keine________Mazel
Turnier_____Eibach (-30mm)_____8,5J18 ET35_____0 mm_________225/40 18___keine________Paulchen
Turnier_____Eibach (-30mm)_____8J18 ET55_______20 mm_________235/40 18___keine________Stefan968
Turnier_____Eibach (-30mm)_____8,5J19 ET40_____0 mm_________235/35 19___keine________dante
Turnier_____H&R (-40mm)_______8J18 ET38______0mm__________235/40 18___keine________Matze NDH
Turnier_____H&R (-40mm)_______9J20 ET40______0mm__________245/30 20___keine________Günnie1981
FLH________OHNE______________8,5J18 ET40_____0mm__________235/40 18___keine________Snowby
Turnier_____H&R (-40mm)_______8x18 ET55______20mm_________235/40 18___keine________AB-MONDEO
FLH________Ohne_______________8,5x20 ET35____0 mm__________245/40 20___Keine________LEvoX
FLH________Eibach (-30mm)______8,5x20 ET50___15mm VA+HA/Rad_245/30 20__keine_______Andos2.5
Felgen / ET Datensammlung, was geht maximal mit TÜV
Andos2.5 -
11. September 2011 um 10:14 -
In your useful file "Rader ET Kalkulator" you didn't insert the "height" of the tyres: for example, my 2010 Mondy fits 235/45-18 while the 2007 models fitted 235/40-18. Do you think that this variation could influence the compatibility between the tyres and wheel arches, expecially using aftermarket wheels and lowering kit? Or /40 and /45 tyres can be considered equivalent?
You are right, but during the time I created the excel sheet there was no difference at the "height".
I have no idea how to consider this.
Jungs ich muss jetzt mal nen update machen
FLH________Eibach (-30mm)_________8,5J20 ET40_____0mm_________245/30 20___keine_______Pit Bull
FLH________OHNE__________________8,5J19 ET40_____16mm________225/40 19___keine_______Black_Mustang2
Turnier_____Ford(-15mm)___________8,5J19 ET40______0mm________255/30 19___keine_______Peter
Turnier_____H&R (-40mm)___________8,5J19 ET45_____10mmHA/Rad__235/35 19___keine________Mazel
Turnier_____Eibach (-30mm)_________8,5J18 ET35_____0 mm_________225/40 18___keine________Paulchen
Turnier_____Eibach (-30mm)_________8J18 ET55_______20 mm_________235/40 18___keine________Stefan968
Turnier_____Eibach (-30mm)_________8,5J19 ET40_____0 mm_________235/35 19___keine________dante
Turnier_____H&R (-40mm)___________8J18 ET38______0mm__________235/40 18___keine________Matze NDH
Turnier_____H&R (-40mm)___________9J20 ET40______0mm__________245/30 20___keine________Günnie1981
FLH________OHNE__________________8,5J18 ET40_____0mm__________235/40 18___keine________Snowby
Turnier_____H&R (-40mm)___________8x18 ET55______20mm_________235/40 18___keine________AB-MONDEO
FLH_______Gewinde (ca. -45mm)___8,5x20 ET35____0 mm__________245/30 20___Keine________LEvoX
FLH________Eibach (-30mm)_________8,5x20 ET50___15mm VA+HA/Rad_245/30 20__keine_______Andos2.5 -
FLH_______Gewinde (ca. -45mm)___8,5x20 ET35____0 mm__________245/40 20___Keine____LEvoX
Turnier_____H&R (-40mm)___________8 J 18 ET45_____0 mm___________235/40 18__keine______kub -
ich würde gerne wissen, ob einer von euch hier die Eibach Federn (-30mm) mit 235/45 R17 und Felgen mit 7,5 x 17, ET45 fährt?
Kann ich da noch 20mm (pro Seite) Spurverbreiterung rein machen und bekomme das eingetragen?
Muss ich dann schon bördeln?
Gruß, der Blaui.
Ist dieser Eintrag korrekt? Auf 20" sollten doch eigentlich 245/30 verbaut sein.
jaaaa RISCHTISCH
mein fehler .... danke
Dear Stefan, in your table when you consider the lowering of the cars, you intend lowering obtained with only the springs (for example the Eibach Pro Kit) or even the dampers?
Many thanks for your helpful technical considerations!!!! -
In your dataset, you can insert the data of my Mondy: Eibach springs (-30 mm), Tomason TN1 8.5"x18" ET=40 wheels, 235/45-18 tyres.
There are no rubbing/stratching between tyres and wheel arches!!!! -
Hello,
the springs define the level of the car not the dampers, also not if you have gas-filled shock absorber. -
FLH________Eibach (-30mm)________ 8,5J20 ET40_____ 0mm_________ 245/30 20___ keine_______ Pit Bull
FLH________OHNE_________________8,5J19 ET40_____ 16mm________ 225/40 19___ keine_______ Black_Mustang2
Turnier_____Ford(-15mm)___________8,5J19 ET40______0mm________ 255/30 19___ keine_______ Peter
Turnier_____H&R (-40mm)__________ 8,5J19 ET45_____ 10mmHA/Rad__ 235/35 19___ keine_______ Mazel
Turnier_____Eibach (-30mm)_________8,5J18 ET35_____ 0 mm_________ 225/40 18___ keine_______ Paulchen
Turnier_____Eibach (-30mm)_________8J18 ET55_______ 20 mm______ 235/40 18___ keine_______ Stefan968
Turnier_____Eibach (-30mm)_________8,5J19 ET40______0 mm_________235/35 19___ keine_______ dante
Turnier_____H&R (-40mm)___________8J18 ET38_______ 0mm_________ 235/40 18___ keine_______ Matze NDH
Turnier_____H&R (-40mm)___________9J20 ET40_______ 0mm_________ 245/30 20___ keine_______ Günnie1981
FLH________OHNE_________________ 8,5J18 ET40_____ 0mm_________ 235/40 18___ keine________Snowby
Turnier_____H&R (-40mm)___________8x18 ET55______ 20mm________ 235/40 18___ keine_______ AB-MONDEO
FLH_______Gewinde (ca. -45mm)__ 8,5x20 ET35____ 0 mm_______245/30 20___Keine_______LEvoX
FLH________Eibach (-30mm)_________8,5x20 ET50_____ 15mm VA+HA/Rad_245/30 20__keine______ Andos2.5So nun kann ich hier auch mal meine Daten preisgeben.
Turnier_____H&R (-40mm)___________________9x20 ET40______0 mm__________255/30 20___keine________Schirkan
Hier gehts zum Bilderfred...Klick
Turnier_____H&R (-40mm)______8,5J19 ET40_____10mm HA/5mm VA Spurplatten__235/35 19__keine______Bertie88
Turnier - Eibach Sportline 45/35 - 9x19 ET43 - keine Spurverbreiterung - 255/35 ZR19 - keine Änderungen - wirthi.m
Turnier_____H&R (-40mm)___________9x20 ET40______0 mm__________255/30 20___keine________Schirkan
Turnier_____H&R (-40mm)___________9x20 ET40______0mm__________245/30/20___keine_____Summavit -
Turnier Eibach (-30mm) 8J18 ET55 VA 20mm/Rad HA 25mm/Rad 235/45 18 keine matthias39112
Turnier_____Ford(-15mm)___________8,5J18 ET45_____0mm__________235/45 18___keine________koe80
Hallo zusammen wollte fragen ob die OZ Superturismo GT 19" auf meinem mondeo (mondeo 2.5T jahrgang 08.2007 Lim.) passen. Das auto ist nicht tiefergelegt.
Mit 235er 35 r19 reifen.
Dimension: 8x19"
Lochkreis: 5x108
Einpresstiefe: 38mm -
Um es kurz zu machen JA sie passen von der Größe her ohne Probleme drunter.
