Beiträge von Syntax
    Hello, I have trailer module 6G9N-14B192-AC and I am wondering if it is suitable for usage in FL Mondeo (2011).
    Or if it can be flashed by different calibration starting AM2J which should be for FL, if so what is the bootloader and calibration file name for it?
    Hello, does anyone know what fuel line should be used for webasto? I have fuel pump DP42 with Webasto VEVO and I would like to know what inner diameter of the fuel line would fit perfectly without attaching connectors to it.
    Also is there a need for some hard plastic fuel line to hold pressure or can it be rubber line used for fuel?
    EDIT: found it here in the section Installation Kit it says "fuel hose Da 5/Di 2/ L 5000" and on aliexpress I have found cheap ones (3mm inner 5mm outer diameter) with clamps
