why does the page not put the same text I type after I press post
Beiträge von Gwe89
Thank you
Am I right in thinking the screen sends the IR signal for the headphones
thank you sir
Is this the pin out numbers for the wires coming out the head rest
Hey does any one have the pin out for the head rest screen plug please
they use the same steering wheel sensor from what I can find
any help much appreciated
any one know what the problem could be please
Hey guys, hope everyone's okay
I saw something about this before but I can not find it any more
I have just fitted the mca + and camera module and i can not get my lines to move on the reverse camera
does any one know how to enable eco mode I have looked through ccc with my ucds but dont see any thing relating to the eco mode
okayy thanks I think I have found some genuine ones with same part number
https://rover.ebay.com/rover/0/0/0?mp…%2F202367688586
Are these any good for the fx
thank you I will take a look at it and do as you say
thank you
Hey I have a fx nav unit that's intermittently turned off and on, now it's won't turn on, I have heard the ram chips go faulty is this the case
Can DAB work with NX unit I have DAB module and it works with my MCA unit but when I put NX unit in there's no DAB option
Hey I'm looking for a graphics board from a faulty MCA navigation unit
looks like I may have too make another ardunio project too recieve ignition on and off cmds and switch a relay
I'm making my own keyless entry with ardunio Leo canbus board and got my sketch sorted alarm module is sorted but I need ignition + to put FOB In Sleep Mode To Save It's Battery And The GND Is For The Door So When You Open The Door It Will activate The Keyless Fob Again Then When I Walk Away From The Car It Will Lock Ect
I have just finished putting my ardunio in a project case
I need it for an alarm module I need an ignition live too tell it ignition has been turned on, I guess I will just have to probe around too see if I can find one,
I also need a GND when the doors open but I think I will have too add a switch for the GND because I don't think there will be a GND
so is there no ignition live any where when ignition comes on there must be a wire somwhere that becomes live
