Hallo Leute,
ich habe eben nochmal nach der TSI wegen des Getriebeupdates gesucht und dabei das hier gefunden:
Finde ich ziemlich interessant, da sind eine Unmenge TSIs und auch ausführliche technische Beschreibungen dazu. Leider in Englisch, was mich aber nicht stört. Das Getriebeupdate findet sich zum Beispiel hier:
9/8/09
Jerkiness during downshifting during decelerations below 15.5 mph (25
km/h)
59/2009
Should a customer express concern about downshifts from 3rd to 2nd gear and from 2nd to 1st gear to be
occurring at slightly higher vehicle speeds in order to avoid the turbine speed dropping below the engine idle
speed, the probable cause is a wrong calibration of the transmission control module (TCM).
Downshifts from 3rd to 2nd gear and from 2nd to 1st gear to be occurring at slightly higher vehicle speeds
in order to avoid the turbine speed dropping below the engine idle speed. The auto-adaptive data of the
transmission calibration has been modified in order to avoid deviations of the adaptive control in case shifts
do occur below engine idle speed. Deleting the TCM data solves the issue for 3rd to 2nd gear downshifts
only for a limited mileage. The downshift from 2nd to 1st gear is not influenced by deleting the TCM data.
For markets where FordEtis IDS is used, connect FordEtis IDS and select the appropriate symptoms from
the concern descriptions above. Follow the FordEtis IDS instructions to rectify this concern.
For markets where FordEtis IDS is not available, use the IDS standard portable diagnostic unit. To rectify
this concern follow the attached service repair instruction.
Use IDS 60.04 DVD or a later version. Before commencing module configuration or programming, connect
the vehicle battery to a suitable external power supply in order to maintain a constant battery voltage
throughout the procedure. For detailed information refer to TSB 62/2007.
Find ich sehr interessant....
