Modell___BJ__Karrosserieform______Federn/Fahrwerk_____________VA / HA Maß
2.2 TDCI_2010__Turnier________Original Titanium S (-10mm)_____38cm / 36cm (Stefan968 )
2.2 TDCI_2009__Turnier________Original Titanium S (-10mm)_____38cm / 36cm (Hman)
2.2 TDCI_2009__Turnier________Original Titanium S (-10mm)_____38cm / 37cm (TitanS)
2,2 TDCI_2008__5tg____________Ford Originalsport FW (-10mm)__37,2 / 36,4 (carbonlippe)
2.0 16V__2010__Turnier________Sportfahrwerk Ford (-10mm)____ 38,5cm/37cm (stefandorp)
2.2 TDCI_2009__Turnier________Ford Sportfedern______________ 38,5cm/37,5cm (longtom76)
2.0 TDCI_2008__Turnier________Ford Sportfedern (-15 mm)______37,5cm/36cm (Ralfonzz)
2,5T____2009__Turnier________ Original Titanium S (-10mm)_____38.0cm / 36.0 cm (s tianium)
2,5T____2009__Turnier_________Nachger. S- Fahrwerk Ford______38,5cm / 36,5 (Rossifan)
2.2 TDCI_2009__Turnier________Original IVDC (-15 Federn Ford??)_37 / 37 cm (McFiscH)
2.0 TDCI_2008__Turnier________Original Titanium X___IVDC _____38cm / 39cm (Papa von (Matze NDH))
2.5T____2008__Turnier________Eibach ProKit (-30mm)__________36cm / 36cm (rainer 777)
2.0 16v__2008__Turnier________Eibach ProKit (-30mm)__________35,5cm / 35,5cm (dante)
2.2 TDCI_2010__Turnier________Eibach ProKit (-30mm)__________36cm / 36cm (Stefan968 )
2.2 TDCI_2010__Turnier________Eibach ProKit (-30mm)nach 20tkm_35cm / 35,5cm (Stefan968 )
2.0i 16V_2008__Turnier________Eibach Pro Kit (-30mm)__________35,0 / 34,8 (carbonlippe)
2.2 TDCI_2011__5tg___________Eibach mit B8/ B6 Dämpfern______35cm / 37cm (EMV)
2.0 TDCI_2008__Turnier________Serie_________________________ 39cm / 38 cm (Matze NDH)
2.0 TDCI_2007__Stufenheck_____H&R (-40mm)__________________35cm /35cm (pflaumendriver)
2.0 TDCI_2009__Turnier________H&R (-40mm)__________________ 35cm /35cm (Matze NDH)
2.0 TDCI_2009__Turnier________H&R (-40mm) nach 20t km_______ 34,5cm /34cm (Matze NDH)
2.o TDCI 2oo9__Turnier________ H&R (-40mm)__________________ 35cm/36cm ( OJ6oo )
2.o TDCI 2oo9__Turnier________ Serie__________________________40cm/40cm ( OJ6oo )
2.0 TDCI_2008__Turnier___Einzelanfertigung + gekürzte Dämpfer __32cm / 31cm (Sundream)
2,5T ____2008__Fließheck__ mod H&R mit gekürzten Konidämpfer_ 31cm/32cm (heavyduck)
2,5T____2008__Turnier____KW Inoox V3________________________35cm/36cm (Peter)
2.2 TDCI_2011__5 Türer________Original Titanium S (-10mm)______37.5cm, hi 38cm
2.0 TDCI_2010__Turnier________Original Titanium S (-10mm)______38cm / 36cm (schnee)
2.2 TDCI_2009__Turnier________Original Titanium S (-10mm)______38cm / 37cm gemessen am 17.03.2010 (Titans)
___________________________________________________________37,5 / 37,0_gemessen am 01.06.2011 (Titans)
___________________________________________unverändert_____ 37,5 / 37,0_gemessen am 31.03.2012 (TitanS)
2.2TDCI 2009 Titanium S_______(40mm H&R)____________________ 34,5cm / 35cm (Bertie88)
2.0TDCI_2007__5 Türer________Serienfahrwerk + IVDC____________39,5cm / 39cm (geldes)
2.0TDCI_2007__5 Türer________15mm + IVDC____________________38,5cm / 38,75cm (geldes)
2.2TDCI_2012_Turnier_________15mm Ford______________________38/35,5 (Teigel)
2.2TDCI_2012_Turnier_________30mm Eibach____________________35/35,5 (Teigel)
2.0 EB_ 2013_Turnier__Eibach Sportline 45/35 auf TS-Seriendämpfer_35cm / 35cm (wirthi.m)
2.0SCTi_2010__Turnier________Eibach Prokit 30 mm______________36 / 36 (CaBaL)
2,0TDCI_2008__Turnier________(40mm H&R Federn)______________34,5 / 34,5 (MondeoCSR)
2.2TDCI_2008__Turnier_______Eibach Prokit (-30 mm)_____________36cm / 36cm (Peter Silie )
2.0Duratec__Turnier_______Serienfahrwerk _____________39,5cm / 39,5cm (bravasx )
2,0 Ecoboost__Tunier______K-Sport Gewinde_____________________32,5cm/33cm(technobase)
Tieferlegungs Datensammlung: wie viel Abstand Radnabe zu Kotflügel habt ihr?
Todde -
4. Juli 2011 um 06:22
Hallo, ich bekomme nächste Woche meinen neuen Gebrauchten Titanium S 2.2 TDCI und wollte mal fragen, wenn ich mir die H&R Federn holen sollte welche müssen es dann sein? Nach welcher Achslast muß ich gucken?
Danke Andi
Du brauchst die über xxxx kg
2.2 TDCI_2009_Limousine____Eibach Pro Kit (-30mm)______________35cm / 34,5cm(inkl. Hifiausbau)(Cosworth) -
So meins ist jetzt auch abgestimmt. Habe ein K-Sport verbaut und habe folgende Abstände vorn/ hinten: 310/ 320mm.
Modell___BJ__Karrosserieform____Federn/Fahrwerk___________VA / HA Maß
2.0 EcoBoost_2014__Turnier________Original Titanium S (-10mm)_____37cm / 35,5cm (FloMue)noch Original...
Hallo an alle,
2.0 TDCi_2013__Turnier________Serienfahrwerk (0mm)_____38,5cm / 39,5cm
Geplant ist noch eine Tieferlegung. Würdet ihr mir Eibach oder H&R empfehlen?
Alus sind in der Größe 8,5 x 19 ET42 235/35 so gut wie bestellt
Am besten etwas einlesen. Es gibt hier bei uns massenweise Threads über das Thema.
Hallo an alle,
Also ich hab mir die H&R bestellt, jedoch noch nicht verbaut. Wird aber so schnell wie möglich gemacht.
2.0 Duratec_2010_Turnier_______Serienfahrwerk_____(0mm)______38,5cm/38,5cm
Die Werte nach dem Wechsel der Federn werde ich noch nachreichen.
Am Dienstag ist es soweit. Werd ja sehen was es ausmacht
So ... also ich habe heute die Federn montiert. Hinten ist er auch ordentlich runter gekommen ... Also die 40mm ... aber vorne nicht. Vorne nur so 20 - 25mm. Gemessen habe ich das vom Radkasten bis mitte Radnabe. Vorher waren die Werte 38,5cm bei der VA u. HA. Nun halt 34,5cm HA und 36cm VA. Senkt sich die Vorderachse dann noch???
H&R sind ja dafür bekannt, daß sie sich bes. vorn noch etwas setzen. Kannst davon ausgehen, daß die vorne noch ca. 1-1,5cm runterkommen. War bei meinem auch.
Falschen Satz Federn bestellt?
Nein ... alles richtig bestellt und auch montiert. Hab aber auch noch die Winterreifen im Kofferraum gehabt. -
Ist ja sehr clever zu messen wenn die Winterreifen noch im Kofferraum sind.
Bei mir hat sich damals nichts mehr gesetzt.
Ich werde nachher mal nach messen und schauen ob sich was geändert hat.
Na hinten bin ich ja soweit zufrieden. Nur vorne ist es etwas wenig wie ich das sehe. Ich messe dann nochmal mit leerem Kofferraum
So ... vorher VA 39cm HA 38cm. Nach Federwechsel und ner Woche ca. fahren VA 36cm HA 34cm. VA könnte wie gesagt ruhig noch etwas runter kommen.
Und ... hat sich noch was getan bei dir??? Bei mir ist die HA links 1cm tiefer als rechts. Wie kann das sein????
Naja, wir haben ja noch kein Bild von dir gesehen...
OH -
