Beiträge von El Pocho
    an124_mk4 ................26.07.2007 ..........2.0L Duratorq TDCI (130PS) Titanium
    DaPlaya9971................16.08.2007...........2.5L Duratec-ST (220PS) Trend
    Scoville..................... 12.10.2007...........2.5L Duratec-ST (220PS) Ghia X
    DaPlaya9971................23.11.2007...........2.0L Duratorq-TDCi (143PS) Titanium
    ArthurDaley................06.12.2007...........2.0L Duratorq-TDCi (130PS) Titanium
    genne.......................18.03.2008...........2.0L Duratorq-TDCi (143PS) Ghia X
    Thoralf.....................15.04.2008.............2,5L Duratec ST (220PS) Titanium X (DK vers.)
    FordFan_71................13.05.2008.............2,3 Duratec HE (160PS) Ghia X
    linza4........................03.10.2008...........2.0L Duratorq-TDCi (115PS) Titanium
    2waq.........................02.05.2009...........2.0L Duratorq-TDCi (143PS) Trend
    bravasx......................31.07.2009...........2.0L Duratec (145PS) Titanium
    Bob_Bob.....................28.03.2010............2.0 Ecoboost in vFl (einer der ersten Ecoboost)
    Erfurter......................29.09.2010...........2,0 Duratec (145 PS) Trend.............. ein ganz alter FL :)
    DeltaF........................07.12.2010...........2.0L Ecoboost (240PS) Titanium S
    Lumi.........................24.02.2011...........1.6L Ecoboost (160PS) Titanium
    Spike1985...................25.02.2011...........2.0L Duratorq DOHC(150/163PS) Titanium
    Endeo........................06.03.2011...........2.2L Duratorq DOHC CR DI (200PS) Titanium
    koe80........................07.11.2011...........2.0L Duratorq DOHC CR TC (140PS) Editionsmodell Mondeo S
    Payne.........................27.11.2011...........2.2L Duratorq DOHC CR DI (200PS) Titanium
    Ossi"..........................29.11.2011...........1.6L Ecoboost (160PS) ChampionEdition
    Ryche.........................30.05.2012...........1.6l Ecoboost (160PS) ChampionsEdition
    El Pocho......................18.06.2012............2.0l Duratorq-TDCi (140PS) ChampionsEdition
    Poldi112.......................24.08.2012............2.0l Duratorq-TDCi (140PS) ChampionsEdition
    RSSB123......................19.03.2013.............2.0l Duratorq-TDCI (163PS) Titanium
    Mondi-Fan....................08.10.2013............2.0l Duratorq-TDCi (140PS) Business Edition
    Mr_Winkler...................04.12.2013............2.0l Duratorq CR TC (140PS) Business Edition
    Weazle........................10.03.2014............2.0L Duratorq DOHC(163PS)Titanium S
    Flori...........................11.06.2014............2.0l Duratorq-TDCi (140PS) Business Edition
    kommaberlin.................23.07.2014............1.6L EcoBoost (160PS) Titanium
    Sven_NRW....................20.08.2014............2,2L Duratorq (200PS) Titanium
    Fritze 1866...................20.08.2014............2.0L Duratorq DOHC (163PS) Titanium S
    So, dann will ich mich auch nochmal dazu äußern.
    Es ist, wie hier die Mehrheit vermutete, die hintere linke Bremse bei mir. Da ich bis Weihnachten noch gute 4tsd Kilometer fahre, hab ich meinen Termin auf morgen vorverlegt und lasse hinten auf ATE tauschen.
    Dass die Bremsteile hinten schneller verschleißen, wurde hier im Forum schon oft besprochen. Ich kann es nur bestätigen.
    Danke für eure Antworten.
    Dann würde doch aber das Quietschen mit der Betätigung der Bremse beginnen. Ich würde definitiv tippen, dass es vorn vorne links kommt. Die hinteren lass ich kurz vor Weihnachtenbei der Inspektion wechseln (ATE).
    Beim Wechsel von Sommer zu Winterreifen war vorne und auch hinten noch "Luft" was den Bremsenwechsel betraf.
    Wieso tritt es nur auf, wenn die Bremse(scheibe) warm ist? Habe ich nach dem Auftreten des Quietschens meinetwegen 100km lang kaum bremsen müssen, taucht es auch nicht auf.
    Mein Mondeo hat mittlerweile knapp 90tkm runter und an den Bremsen wurde noch nichts gemacht (nahezu ausschließlich auf Autobahn unterwegs). Seit kurzem fängt es an zu fiepen, höchstwahrscheinlich wenn die Bremse warm/heiß ist. Morgens ist alles ruhig. Nach dem ersten Stau geht's los. Das Geräusch tritt im Bereich bis ca 100kmh auf danach ist es weg. Es verschwindet auch sofort sobald die Bremse betätigt wird.
    Daher denke ich, dass die Bremse noch nicht runter ist, die Scheiben sehen auch noch gut aus.
    Woran könnte es liegen? Muss ich die entsprechenden Teile wechseln?
    Bremsleistung ist übrigens normal.
    Kleine Geschichte zur SD Karte und den Preisen....
    Konnte nicht mehr warten, also hab ich beim Freundlichen in Berlin nachgefragt... 121 Euro...ahja...
    Beruflich gerade in Köln unterwegs also wieder zum Freundlichen... 229 Euro. Ich bin fast umgefallen! Dann hab ich mal auf die eigene Ford Zubehör Seite hingewiesen, wo die SD für 99 Euro drin ist. Nachdem zwei Mitarbeiter und ein Meister sich damit 30 Minuten beschäftigten, hab ich die Karte auf eigene Gefahr bestellt. Die Karte funktioniert natürlich.
    Sorry, aber wenn das so schön bei SD Karten läuft, bin ich froh, dass ich noch keine Reparatur benötigte.
    Nokian macht zur Zeit gute Reifen. Ein Kollege fährt das Exemplar auf einem Fiesta Sport Red Edition und hatte noch nichts zu klagen. Meinem Vater werde ich auch die Nokian auf seinen Kuga montieren.
    Auch in den einschlägigen Testberichten kommen die immer gut weg.
    Eine milde APC (All Purpose Cleaner) Mischung (am besten mit Dest. Wasser) oder einem guten Textilreiniger (z.B. Surf City Garage Dash Away). Wahrscheinlich reicht auch ein billiger Schaumreiniger aus dem Baumarkt. Wie schon gesagt wurde...die ganze Fläche behandeln, sonst hast du immer wieder Wasserränder.
    Ich bin demnächst beruflich unter der Woche im Außendienst unterwegs und habe eine Anzugspflicht. Also wird der Mondeo dank seiner Größe ein mobiler Kleiderschrank. Fraglich ist nur wie ich die Anzüge und Hemden am besten transportiere... (weissnicht)
    Gibt es vielleicht Geschäftsreisende mit Tipps?
    Gibt es solche "Kleiderbügel" für die Rückseite des Sitzes auch original von Ford?
    Falls nicht, gibt es empfehlenswerte von Drittanbietern?
    Mmh den Tourneo Custom hatte ich mal als Mietwagen. Vorn vorn find ich den nicht gut. Von hinten schon besser. Innenraum fand ich billig, da es stark dem Fiestau usw. ähnelte. Vom Fahren aber in Ordnung.
    Würde dann aber lieber zum T5/T6 bzw zum Vito (günstiger als VW) oder zur neuen V-Klasse greifen.
